VRS PD TDI NO BOOST FROM IDLE TO 2500
Help needed my car won't pull away without loads of revs. Also have no power between idle and 2500 then it pulls like a train. No error codes stored, checked turbo inlet vanes look good and no play. I have ordered a new n75 valve.any other ideas would be most helpful
Had a similar problem with my 2.0 VRS PD.  Used to stall a bit on me when trying to pull away and got a bit embarrassing, as it felt as I was a learner driver....  When the turbo kicked in, there was tons of torque.
When my injectors was replaced with the Skoda injector recall, it drove like a different car, pulls away a lot stronger and was more smoother at the lower rev range.  Perhaps this may be the problem with your car?
I had my injectors done on the recall years ago so I hope it's not them
Also should say I've had the dpf removed and it's mapped. Going to speak to the tuners tomorrow
