Detachable boot light
Hi!
I have not noticed that behavior so the torch function do not operate at all.
I have opened  the torch and many electronics inside for a simple torch, Wow!
I have checked that the 3 original AAA batteries are completely dead, no voltage and they do not get charge with and external charge.
I have just purchased a blister of AAA fresh eneloop rechargeable batteries, installed on it, and...... NOTHING!!!
Seriously, my torch is completly dead!! Probably some problem in the electronics.
Im thinking about probably no failure in car pins (the third one can be a data communication wire, due to complex electronics inside, so no real voltage there.... I think)
New torch? Ummm it is expensive, i will look for an affordable one. I like to keep the car with original fuctions as possible.
Regards.
14 hours ago, ferdinandus said:
Hi!
Regards.
I'd just try and get a second hand one from a breaker's yard. Should cost peanuts. Good luck.
  • 2 years later...
Can you guys help me how to open the Torsh to change the battery ?
To @Adamsalam - I try to open my, with no success. It is very strong and I can not find something like tutorial. Are You sure that the Problem with yours is in battery? I ask my Friend with the same Car, to try his torch, that is working for sure but in my Car the torch does not work. I find that the failed fuse was the Problem and now my torch is working again..
