Driver door won't open
Hi,
When the temperature drops down to about freezing point or lower, the driver door won't unlock. I can hear the lock moving when used the remote, but I cannot open the door.
If I go in the passenger side the door is easily opened from the inside.
After the door has been opened it works perfectly until the next day.
Any good ideas?
The catch freezing slightly, spray some lubrication spray like plus gas on th the metal piece in door shut, and the black lock mechanism in door
Ok, I'll try that tomorrow. Thanks
Does you outside door handle move?
If it's the door seals frozen to the car body then use this stuff.
Einszett Gummi Pflege
Einszett Gummi Pflege / Rubber Care Stick - 100ml
Gummi Pflege provides real, deep down protection, helping to prolong the life of rubber seals, gaskets and trims, providing protection against cold, heat and UV radiation from the sun.
Rubber seals around windows and doors often go untreated and deteriorate over the course of time. Usually this is the result of changing temperatures and high UV sunlight exposure. A classic indication of rubber deterioration is when the rubber starts to dry out, crack, or shrink. When this happens the integrity of the seal can become ineffective and fail which can often lead to further problems such as squeaks, whistles, draughts and leaks. Cosmetically, the original luster is lost and the rubber continues to perish.
Unlike many treatments for rubber, Gummi Pflege doesn't simply buff rubber to look new. Gummi Pflege provides real, deep down protection, helping to prolong the life of rubber seals, gaskets and trims, providing protection against cold, heat and UV radiation from the sun.
Features:
• Anti freezing protection. Stops doors sticking in cold temperatures
• Easy and quick to apply – shoe polish style applicator sponge ensures no mess
• Protects rubber seals against high and low temperatures
• UV protection prevents rubber from perishing, cracking, or hardening
• Solvent-free and water-based rubber protection
• Rejuvenates rubber to maintain elasticity for longer
To Use:
Gummi Pflege rubber protection is quick and easy to apply – simply run the sponge applicator along the rubber trim and you're finished.
Some uses for Gummi Pflege include:
a) Hard / Dryed out door rubber seals can create friction between the door glass & rubber. Use Gummi Pflege to keep the rubber supple and elastic thereby preventing the Window mechanism (the regulator) from wearing
B) Wind Deflectors fit in to the door window channel. Dryed and hard rubber seals make it difficult to fit wind deflectors. Use Gummi Pflege to treat the rubber before fitting to ensure a perfect snug fit.
I had the same problem regularly on my Passat and used this on the seals and never had the problem again, I've used it on my superb as well as prevention.
The outdoor handle moves. But it is easy to open the door from the inside, not like if it ís the rubber that is freezing to the door.
