Front Mount Intercooler With XENONS?
So I Have heard that because i have xenon headlight washers, i can not install a FMIC ?
Is this Correct?
No, well not particularly correct. I have heard the DS one doesn't but mine has a forge and I have factory fit xenons.
Spot on.
Anything "SEAT-Sport" style - twin pass with a high return pipe is likely to have problems.
Pretty much only the forge will fit.
I had a seat sport and oem xenons
Removed the washer system to fit fmic. No biggy really
i got seat sport and xenons and darksides hardpipes need major modification
Did you remove washers?
i retro fitted xenon's (genuine) and the top boost pipe hits the rear of the ballest on the rear of the headlight ive removed the fuel filter holder for now and it just fits
Forge is the easiest option IMO.
if you want to retain the washers for MOT purposes.
