Cold start problems.
Have an 07 plate PD170 engined octavia. It hates the cold and simply will not start.
Anyone else experienced similar?
Will a new battery solve it or is there a (bigger???) problem elsewhere?
Cheers.
Bigger issue im afraid, I suffer with my VRS as do many others on this forum and on the VW forums too.. seems to be a common issue with VAG engines (PD170)
My car seems to have been a problem since the injector recall and feels less powerful too!! tried new battery and although marginally better its not fixed it..
Ive heard rumours of it poss being a crank shaft sensor but unconfirmed so far!!
save your money replacing glow plugs etc, apparently not the issue.. im sure people will chime in on this soon... but keep cranking it over without throttle and it will start and run lumpy for a bit then sort itself out
Same/similar problem.
Could be
Coolant temp sensor
Fuel delivery/pressures low
Engine compression low
Glow plugs not working correctly
Leak in fuel system
Water in fuel filter
Priming lift pump when drivers door is open not working
Tandem pump broken
In tank electric lift pump
Temp sensor two separate elements
Camshaft sensor
Crankshaft sensor
http://www.briskoda.net/forums/topic/339123-cold-starting-issues-running-out-of-ideas/
If I understand it correctly, the PD170 is the worst that man can wish their enemies ?!  :notme:
50% of the post consists of the problems with this engine and always adds 'common' problem. People continue to climb the same mistakes and asks the same questions. Each manufacturer commits an error, and the error from VAG is PD170 engine. Maybe think about before you buy them?
@ silver1011 Now I look forward to cursing on the opening of a new post on an old theme.  :giggle:
Could be
Coolant temp sensor
Leak in fuel system
Tandem pump broken
Camshaft sensor
Crankshaft sensor
You forgot an air in fuel system...common after fuel filter replace ;)
Haha! :D
Nothing more to add other than the cold starting issue on my PD170 (also after the injector recall) was enough to me to cut my losses.
For what its worth my local Skoda dealer had my car on and off for almost 8 weeks, changed and adjusted several parts (totalling thousands of pounds), they even hooked it up to the internet so that Skoda in the Czech Republic could take a look at the results.
"Nothing more we can do sir, you'll have to wait until it gets worse." I didn't wait.
This subforum really does make for sad reading these days with all these post-recall PD170 problems. I hope you guys get some resolution at some point. It's such a shame - I LOVED my remapped PD170 before the injector recall.
I also loved mine until the dealers got their hands on it and messed up the injector change.
So off the back of all this cold start issues because of injectors would it be worth starting a thread based on those having issues so we can get an idea for how many people are suffering? and then take this to Skoda??
