Pioneer AVH-X3500dab - hand brake bypass
Hi Guys,
Just won a pioneer AVH-x3500dab from the bay.
I want to bypass the hand brake function so videos/dvds will play whilst in motion.
I have seen numerous videos on youtube but in one the chap simply took the lead and put a connector on it then screwed it to the actual metal body of the head unit.
Will this work?
Or would splicing it into another cable back there be better?
Many thanks
Matt
Had one in my previous Saab and yes it will work if you ground the handbrake cable.
So any ground then? to the body of the car or the body of the stereo or even splice into ground wire?
yes, I used a nut on the dash mainframe (car body), just stripped the wire back, loosen the nut, wrap around thread and tighten up. The wire when connected to the handbrake just goes to ground when the lever is up so it cannot be used when off you are just supplying a permanent ground.
Pioneer won't work that way as it requires a pulse signal not a constant signal so you just need a relay and a few bits of wire and connectors. There a few videos on YouTube to do this method
now i am confused!
I have the none dab version fitted. It's only 3 quid tops for the relay
I think that may be the older Pioneer units and Kenwood that use a relay, pretty sure I just grounded this exact unit. Either way you tube tells all, give it a go cant hurt.
I had a fairly new pioneer unit and it could sense it was grounded, swapped to relay and it bypassed the handbrake perfectly, it takes about 10mins to knock up a bypass harness and a 4 pin relay.
When radio sends pulse to amp cable it routes it to relay, relay turns power to other pin, radio thinks handbrake is applied.
thanks guys, youtube helped, relay wired ready for install.
any tips on routing new aerial cable from roof to back of hu
