Bluetooth Modules
I currently have Bluetooth Modules No 5NO 035 730 C fitted in my car and it gives me everything I need apart from music/audio streaming.It works flawlessly including voice control,I have been told that model No 3C8 035 730 D would do all this plus the audio streaming can anybody confirm this and is there another model that can give me all that I want.Idealy I'm looking for something that I can just plug in and away you go as I have no way of coding etc.In a way I'm loathed to play about with it to much as everything else is working so well but the streaming would be a great advantage as I could then use my phone as a satnav without using it through the aux connection as I do now.looking forward to your comments/suggestions etc
Is yours a facelift model with maxidot? If so it will work. It should be pre-coded and will probably work out of the box although for full functionality you may need some coding.
Yes it is a f/l and it's got maxi dot. Coding would be of a problem tho
As I said it may be fine anyway. Check out the members with vcds map in the vcds section for someone nearby. If you are ever passing over the bridge I will look at it for you.
Ok, thanks for the offer will keep you in mind
