Engine problem
I went to pull off last night, was cold but not too bad. The Engine stalled but I know it wasn't a fault of mine, I quickly started up and manged to pull off but there was very little power. I was able to switch into second and third but when I pushed the gas there was nothing. As I was pressing the gas and even when I wasn't, the Engine warning light was coming on and off. When i pulled over, the engine felt like it was about to stall so I just turned it off, after started it up again It felt the same.
I tried again this morning and I was getting the same, however, When I firsted switch the car on, the engine sounded fine and didn't seem to stall. Was only after pulling off I started to get the problems.
Any help would be great, I've rang a garage and they said it They couldn't look at it until next wednesday...
Thanks,
  • Sponsor
Meadsy; not all Fabias have the same engine, can you narrow it down a bit for us?
Petrol/diesel?
Engine size?
No. of valves?
Engine Code (a three letter code summarising all of the above info)?
Petrol/diesel?
Engine size?
No. of valves?
Sorry, Its a 1.2 HTP
