Fuel Temp Sensor location on vRS?
Can anyone tell me where this sensor is located in my vRS engine bay?
I've done a search, and the only post that discusses it in depth contains a few red herrings and a link to an article on a mod, but the pics don't show up anymore.
I've seen reference to it being of steel rather than plastic, and there is a circular device attached to the bulkhead, but don't know whether that's it. I've also seen reference to it being off the tandem pump - is that the pump attached to the right hand side of the engine? On a dark, cold winter's day nothing's obvious!
I've attached a pic of my engine in case it helps.
Thanks!
where the lower fuel pipe turns down on the right hand side there is a short length of rubber then it should be the sensor  not sure what's happened on yours   seems unlikely it's missing or someone's moved it--- just follow thro' the return system from head back to the thermo' valve on the fuel filter
Thanks for the info - I've circled the location I think you mean, in another attachment - is that correct?
yup :sun:
Got it!
Cheers :-)
  • 2 years later...
Bit of a thread revival:
Any ideas what replacing the sensor consists of?
I have a fault code for the fuel temperature sensor, I assume the area circled, and as you describe, is the place I should be aiming for.
I have yet to open the bonnet and have a look, I assume it is connected by the wire 'crimp' circ clips?
Many thanks
JRJG
