drivers door card removal
Hi can someone help me regarding this, there is two screws at bottom of card. and two behind switch panel i think, is there any others i need to know about so i dont break anything??
There is also one behind the trim with the mirror switch and small speaker at the top of the door. The trim just prises off.
cheers fella, i take it after i pop off all the clips is it best to remove at an angle, the last car i did was a vectra i had to angle it at 45 degrees for the card to come off easier.
Yes angle it up from bottom and lift off detaching cabling carefully. You will probably need some new clips from eBay to put it back as they tend to break on removal. There are six, three either side as I recall.
Cheers mate got some clips when I was in skoda the other day, Im very heavy handed lol
No prob.  Even light handed you will need them!!!
There are 4 behind the switch pannel. 3 T30 and 1 T15 or T20 I cant remember exactly.
As above be careful and good idea on getting clips. You might break the plastic on the door card holding the clips in place so have some glue and needle nose plyers on stand-by too
  • 5 months later...
Cheers needed some of the spares in the end :)
