Knocking sound!
just bought a 06 plate vrs fabia as I was driving it back i could here a knocking noise coming from the front of the engine,it's sounds like it's coming from the right hand side and the left any ideas? Future more the main trip computer doesn't turn on just a blank screen.
Did you take the car for a 'proper' test drive before buying?
Did you buy from dealer or private.i would get under bonnet asap with engine running and diagnose
Where abouts in Lancaster are you?
If you don't have any luck or find out what it is I could meet you and we can compare 'what should be' and 'what shouldn't be' making noises ?
Did you buy it locally?
JRJG
could be anything need more detail common problems are droplinks
It's droplinks.
It's more creaking then anything need to take a proper look under the car and check everything I had a feeling it might be the cv joint but it dose it all the time even when I'm freewheeling
Got it from a garage everything seems fine untill I drove home which was about 70miles
could be snapped spring
Check for that and it's not
