Trim removal - HELP!
Hi Guys,
had a go at fitting a new roof mount DAB aerial today, it took a while and some swearing but finally got all the cables routed to [passenger footwell and didn't break a clip :)
Left with one piece of trim to go in and it the passenger side sill piece.
when I removed it, it popped out from under neath the trim piece on the centre piller (the one behind the passengers seat belt).
BUT i can not get it to go back in due to the length it can't bend enough to go up under neath the trim piece again.
I thought ok I will remove the seat belt trim piece BUT no matter how hard I pull it won't budge and Im scared ill break it.
Any help please guys?!?! Is it just clipped in place?
Matt
  • Sponsor
I think when I've removed the b-pillar trims I've started with the upper piece, then removed the lower. I can't remember if it's essential that it happens in this order, but maybe worth a try?
