Cutting out at low revs
Hi,
I have a 2002 Fabia 1.4mpi and have a problem with it cutting out. Sometimes it cuts out the first few times I start it, when at low revs or idling. Once it's had a good run it gets better.
I have scanned it and get the following codes;
VCDS-Lite Version: Release 1.2
Thursday, 12 February 2015, 19:35:45.
Chassis Type: 6Y - Skoda Fabia I
Scan: 01,02,03,08,09,15,17,19,25,37,44,46,55,56,76
Address 01: Engine       Labels: Redir Fail!
   Controller: 047 906 033 C
   Component: 1,4l SIMOS3PA   00HSSJ4C
   Coding: 00061
   Shop #: WSC 13765
   VCID: 13593C4F726D
   TMBPB16Y023449756     SKZ7Z0A1233057
5 Faults Found:
17549 -  Load Calculation Cross Check: Implausible Value
            P1141 - 35-00 -   -
16556 - Shareware Version. To Decode all DTCs
            P0172 - 35-10 - Please Register/Activate - Intermittent
17526 - Shareware Version. To Decode all DTCs
            P1118 - 35-10 - Please Register/Activate - Intermittent
17564 -  Manifold Pressure Sensor (G71): Open/Short to Ground
            P1156 - 35-10 -   - - Intermittent
17658 - Shareware Version. To Decode all DTCs
            P1250 - 35-00 - Please Register/Activate
Readiness: 0010 0101
Address 08: Auto HVAC       Labels: 6Q0-820-045.LBL
   Controller: 6Y0 820 045
   Component: Klimaanlage        X0830
   VCID: F297D9CBADB7
5 Faults Found:
00818 -  Sensor for Evaporator Outlet Temperature (G263)
            30-00 -  Open or Short to Plus
01596 - Shareware Version. To Decode all DTCs
            30-10 - Please Register/Activate - Intermittent
            41-10 - Please Register/Activate - Intermittent
01596 -  Motor for Outside/Recirculated Air Flap (V154)
            29-10 -  Short to Ground - Intermittent
            28-10 - Please Register/Activate - Intermittent
I thought the issue was to do with the Lambda sensor so I was going to replace or reseat it but I don't know where to find it.
Any help would be appreciated.
Thank you
Edited by MCostello
Try cleaning and resetting the throttle body, also check that the thermostat hasn't broken up by removing the engine coolant temperature sensor (when the engine is cold) and having a look.
Thanks fordfan, I'll give that a go on Saturday
After quick checking that error codes, I'd say that is time to replace or at least to test the G71 (MAF) sensor. You might want to read this before getting to work.
I recently changed the maf sensor and still get the errors. I'm thinking it must be a wiring problem?
