Citigo Black Edition lowering springs
Can anyone recommend me some lowering springs for Citigo Black Edition?
I'm not sure how much of a drop to go for, so if you could post a few photos of your lowered Citigo's and say which springs you've used, it'd be much appreciated thanks.
It's a difficult subject aftermarket springs, I've found my local dealer won't touch them (even the standard greentech springs) and another Skoda dealer only fit the Greentech springs (15mm drop) and not aftermarket springs, also insurance will likely charge you for lowering even if you chose factory springs, here's a email from a Skoda dealer I received when asking about it
Thanks for the email. As far as I'm aware there is no warranty issues if the springs are a genuine Skoda accessory.
Aftermarket ones are a grey area but I see it like this: You can do whatever you want with a car. There only becomes a warranty issue if whatever has been changed on the car causes the problem. i.e. if you changed the springs and it caused an issue with steering sensors or the suspension, then it may not be covered. However if something unrelated breaks i.e. The radio stops working, then it would be covered. I hope this all makes sense!
  • Sponsor
Hi,
If you find you have any issues with insurance at all then please feel free to drop me a line. I would be only too please to try and help.
Regards,
Dan.
Don't fit springs as your radio will stop working [emoji16][emoji6]
I'm guessing there is a story behind this?
Sorry, very slow on the uptake this evening it seems.
Thanks for the info/advice so far.
Has anyone tried H&R -35mm lowering springs? If so, photos please :happy:
H&R monotube coil 28953-1 Tieferlegung VA: 40-60 | Tieferlegung HA: 35-60
16 inch 7j offset front 20, offset rear 7
165 45 16 tyres
H&R adapters front 22mm, rear 35mm from 4x100 to 5x112
Down 35 by H&R springs
165 45 16 tyres
Thanks for the photos. It looks like the H&R -35mm springs will be good for me.
I'm still running the stock 15" alloys but plan on getting different alloys at some point, possibly 15", maybe 16".
