Mk4 Golf coilovers?
Do mk4 golf coilovers fit? Or can they be made to fit?
  • Sponsor
No
Damian @ DPM Performance
Polo ones will
Mk4 golf coilovers can be made to fit, yes.
Do they fit: No
Can they be modified to fit: Of course
I have some kw v2's coilovers for sale ☺
How much??
Getting some on the cheap because mine have given up haha.. What needs to be done to make them fit??
Re drill the top mount hole.
That's about it.
How much??
£500 mate
That's about it.
Can you elaborate on this? Got the chance to get some decent ones for free
The mk4 golf uses a round top mount bush which sits inside the chassis, and then a cup is placed on top through the centre hole and bolted together.
On the fsbia, they're mounted using the 3 small holes around the centre hole.
The centre hole on the fsbia is too small to take the retaining cup for the mk4 top mount. Make this hole large enough to fit the cup... And you're done. :)
Sounds like too much effort lol
Too much effort to drill 2 holes? Takes less than 10 minutes.
Mk4 coilovers iirc bolt to the hub where fabia ones fit inside the hub. Fabia ones are tapered down at the bottom to fit the hub.
I've got Mk4 golf shocks etc fitted to my Fab mate.
The dampers are the same.
Just remembered its MK3s that have the bolts!
Just found out the ones I was offered have a leaky shock anyway...
