Fabia vrs o/s/f coil spring replacement
Hi
Hope you can help
Need to replace snapped coil spring and before I dive in and start i'am hoping for some pointers
1) is it easier to remove shocker with hub still attached
2) if removed from hub. Is the shocker/keyed as to get correct alignment and stop shocker going into far
3) is the anti roll bar link arm easy to disconnect ie spanner/Allen key to stop it turning or just get a new one
Anything else I need to know would be great
Edited by Snapper1725
