VCDS coding information
Hi guys,
I am Francisco from Spain.
First of all, excuse me if my English is not really correct.
I have an Octavia III Combi 140 CV DSG from June of pass year 2014.
The ECU’s list is the following:
Saturday,27,December,2014,17:06:48:62939
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: Release 12.12.0 (x64)
Data version: 20130910
Dealer/Shop Name: FRANCISCO
VIN:    License Plate:
Mileage:    Repair Order: CONFIGURATION 27-12-2014
Chassis Type: NE (5Q0)
Scan: 01 02 03 08 09 10 13 15 16 17 19 42 44 52 55 5F A5
VIN: TMBJC9NEXE0223528
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
13-Auto Dist. Reg -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Xenon Range -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
A5-Frt Sens. Drv. Assist -- Status: OK 0000
Address 01: Engine (J623-CHPA)       Labels: 04E-907-309-V1.clb
   Part No SW: 04E 906 016 G    HW: 04E 907 309 A
   Component: 1,4l R4 TSI   H09 6185
   Revision: WAH09---
   Coding: 01250032232401080000
   Shop #: WSC 73430 031 00121
   ASAM Dataset: EV_ECM14TFS01104E906016G 002009
   ROD: EV_ECM14TFS01104E906016G_SK37.rod
   VCID: 264310135912D62ECEF-8073
No fault code found.
Readiness: 0000 0000
Address 02: Auto Trans (J743)       Labels: 0CW-927-769.clb
   Part No SW: 0CW 300 046 B    HW: 0AM 927 769 K
   Component: GSG DQ200-MQB H43 5110
   Revision: 00043014    Serial number: CU501404175278
   Coding: 0014
   ASAM Dataset: EV_TCMDQ200021 001001
   ROD: EV_TCMDQ200021.rod
   VCID: 3979CB6FB8AC49D693D-806C
Address 03: ABS Brakes (J104)       Labels: 5Q0-907-379.clb
   Part No SW: 5Q0 907 379 R    HW: 5Q0 907 379 F
   Component: EMB8 EHCB     H31 0356
   Revision: 00000000    Serial number: 61054000000171
   Coding: 1C076A912422116F007C060241CB243856248800608224F0F0210070C002
   Shop #: WSC 73430 031 00063
   ASAM Dataset: EV_Brake1UDSContiMK100ESP 033001
   ROD: EV_Brake1UDSContiMK100ESP_SK37.rod
   VCID: 4B9581A7E230CB46311-801E
Address 08: Auto HVAC (J255)       Labels: 5G0-907-044.clb
   Part No SW: 5E0 907 044 K    HW: 5E0 907 044 K
   Component: Climatronic   H03 0907
   Revision: 00001K06
   Coding: 02010004000100011005000000100000
   ASAM Dataset: EV_ACClimaBHBVW37X 003017
   ROD: EV_ACClimaBHBVW37X_SK37.rod
   VCID: 2D51EF3F7CE4E5760F5-8078
   Fresh Air Blower Front:
   Refrigerant Pressure And Temperature Sender:
   Air quality sensor:
Address 09: Cent. Elect. (J519)       Labels: None
   Part No SW: 5Q0 937 086 Q    HW: 5Q0 937 086 Q
   Component: BCM PQ37BOSCH 026 0097
   Revision: --------    Serial number: 86580205140981
   Coding: 0C001A42424722FB47E04000000C07280000000000000000000000000000
   Shop #: WSC 73430 790 00121
   ASAM Dataset: EV_BodyContrModul1UDSBosc 012003
   ROD: EV_BCMBOSCH_AU37.rod
   VCID: 489FBEABF346205E1C3-801D
   Subsystem 1 - Part No SW: 5E1 955 119     HW: 5E1 955 119
   Component: WWS371 140415  041 0570
   Serial number:         140424131103
   Coding: 065DDD
   Subsystem 2 - Part No SW: 5Q0 955 547     HW: 5Q0 955 547
   Component: RLFS  024 0042
   Serial number: Y14M04D29H11M45S58S2
   Coding: 02805D
Address 10: Park/Steer Assist (J791)       Labels: 5Q0-919-294.clb
   Part No SW: 5Q0 919 294 F    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  H03 0142
   Revision: --------    Serial number: 39331412002079
   Coding: 0031051051
   Shop #: WSC 73430 790 00063
   ASAM Dataset: EV_EPHVA18AU3700000 002024
   ROD: EV_EPHVA18AU3700000_SE37.rod
   VCID: 3E73D873A1826EEEA6F-806B
Address 13: Auto Dist. Reg (J428)       Labels: None
   Part No SW: 5Q0 907 572 B    HW: 5Q0 907 572 B
   Component: ACC Bosch MQB H04 0200
   Serial number: 03041477031189
   Coding: 00001600FE0339
   ASAM Dataset: EV_ACCMRRBoschVW372 001014
   ROD: EV_ACCMRRBoschVW372_SE37.rod
   VCID: 3663C05389B2A6AE7EF-8063
Address 15: Airbags (J234)       Labels: Redir Fail!
   Part No SW: 3Q0 959 655 AA    HW: 3Q0 959 655 AA
   Component: Airbag VW20   012 0189
   Revision: --------    Serial number: 003NYP7YQKKK
   Coding: 98FCC000000000005C5400CC000800000065
   ASAM Dataset: EV_AirbaVW20TS6VW48X 001116
   ROD: EV_AirbaVW20TS6VW48X_SK37.rod
   VCID: 7DF11F7FEC04B5F6FF5-8028
   Seat belt tensioner; left:
   Subsystem 1 - Part No SW: 5G0 980 945 B    HW: 5G0 980 945 B
   Component: BeltPretRevFL  H35 0341
   Serial number: 34169593B05051471165
   Coding: 333135
   Seat belt tensioner; right:
   Subsystem 2 - Part No SW: 5G0 980 946 B    HW: 5G0 980 946 B
   Component: BeltPretRevFR  H35 0341
   Serial number: 34169592B05051470826
   Coding: 333135
   Crash sensor for side airbag; driver side:
   Subsystem 3 - Part No SW: -----------    HW: 454 002 104 14
   Component: SideSensor_Df  008 0887
   Serial number: 3576U000000019896F0D
   Coding: 2D2D2D
   Crash sensor for side airbag; passenger side:
   Subsystem 4 - Part No SW: -----------    HW: 454 002 104 14
   Component: SideSensor_Pf  008 0887
   Serial number: 3586U00000032AA0AF0G
   Coding: 2D2D2D
   Crash sensor for side airbag; rear driver side:
   Subsystem 5 - Part No SW: -----------    HW: 454 802 004 14
   Component: SideSensor_Dr  111 0148
   Serial number: 3516R41CF63030000000
   Coding: 2D2D2D
   Crash sensor for side airbag; rear passenger side:
   Subsystem 6 - Part No SW: -----------    HW: 454 802 004 14
   Component: SideSensor_Pr  111 0148
   Serial number: 3526R479B6003000000/
   Coding: 2D2D2D
   Crash sensor for front airbag; driver side:
   Subsystem 7 - Part No SW: -----------    HW: 454 800 103 14
   Component: FrontSensor_D  114 0149
   Serial number: 3556VAE3604030000004
   Coding: 2D2D2D
Address 16: Steering wheel (J527)       Labels: 5Q0-953-549.clb
   Part No SW: 5Q0 953 507 DF    HW: 5Q0 953 549 C
   Component: Lenks. Modul  002 0110
   Revision: --------    Serial number: 05051404220174
   Coding: 1410
   ASAM Dataset: EV_SMLSKLOMQB 017001
   ROD: EV_SMLSKLOMQB.rod
Address 17: Instruments (J285)       Labels: 5G0-920-XXX-17.clb
   Part No SW: 5E0 920 871 B    HW: 5E0 920 871 B
   Component: KOMBI         333 2210
   Coding: 07A40A086980000801883A03000000
   ASAM Dataset: EV_DashBoardVDDMQBAB 008031
   ROD: EV_DashBoardVDDMQBAB_AU37.rod
   VCID: 275D1D175E18CF26F59-8072
Address 19: CAN Gateway (J533)       Labels: None
   Part No SW: 5Q0 907 530 Q    HW: 5Q0 907 530 F
   Component: GW MQB High   125 1164
   Revision: --------    Serial number: 0001925158
   Coding: 030100042F085700EF00024E1C0F00010001050000000000000000000000
   ASAM Dataset: EV_GatewLear 010015
   ROD: EV_GatewLear_AU37.rod
   VCID: 3F8DA577A68867E6AD9-806A
   Generator:
   Multifunction unit control module:
   Subsystem 2 - Part No SW: 5E0 919 719 B    HW: 5E0 919 719 B
   Component: E221__MFL-PR6  H04 0130
   Serial number: 000000000B0244260414
   Battery Monitoring Control Module:
   Subsystem 3 - Part No SW: 5Q0 915 181 E    HW: 5Q0 915 181 E
   Component: J367-BDMHella  H03 8043
   Serial number: 3406303203
Address 42: Door Elect, Driver (O386)       Labels: None
   Part No SW: 0Q4 959 5<3 B    HW: 0Q4 959 5<3 B
   Component: QSG FS %      059 0514
   Serial number: 5000101556180
   Coding: 05150120D000048500001100
   Shop #: WSC 73430 790 41081
   ASAM Dataset: @V_DCUDwiveSid`EWMAXCJNT 506001
   ROD: N/A
   VCID: 428BAC83D57A0A0EC27-8017
No ASAM data for: "@V_DCUDwiveSid`EWMAXCJNT" (SK37)
1 Fault Found:
66919 - ROD - Unknown Error Code
          - 00 [008]
          Intermittent - Confirmed - Tested Since Memory Clear
Address 44: Steering Assist (J500)       Labels: 5Q0-909-144.clb
   Part No SW: 5Q0 909 144 P    HW: 5Q0 909 144 P
   Component: EPS_MQB_ZFLS  122 1043
   Coding: 9102
   ASAM Dataset: EV_SteerAssisMQB 010031
   ROD: EV_SteerAssisMQB.rod
   VCID: 4189A38FD07C1116DBD-8014
Address 52: Door Elect, Pass. (J387)       Labels: None
   Part No SW: 5Q4 959 592 B    HW: 5Q4 959 592 B
   Component: TSG BFS       009 0014
   Serial number: 0000101584972
   Coding: 00150120D000048000001100
   ASAM Dataset: EV_DCUPasseSideEWMAXCONT 006001
   ROD: EV_DCUPasseSideEWMAXCONT.rod
   VCID: 4385A987CA600306C91-8016
   Subsystem 1 - Part No SW: 5Q0 959 812 A    HW: 5Q0 959 812 A
   Component: FOND_FHSG_PSG  005 0005
   Serial number: 00000000000002482179
   Coding: 190200
Address 55: Xenon Range (J745)       Labels: 7P6-907-357.clb
   Part No SW: 7P6 907 357 D    HW: 7P6 907 357 A
   Component: AFS-ECU       H07 0090
   Revision: --------    Serial number: --------------
   Coding: 03CA02003F000000
   ASAM Dataset: EV_HeadlRegulVWAFSMQB 001120
   ROD: EV_HeadlRegulVWAFSMQB.rod
   VCID: 408FA68BDB76181ED43-8015
   Subsystem 1 - Part No SW: 1T0 941 329 B    HW: 1T0 941 329 B
   Component: LeiMo links  H06 0009
   Coding: 3E0000
   Subsystem 2 - Part No SW: 1T0 941 329 B    HW: 1T0 941 329 B
   Component: LeiMo rechts  H06 0009
   Coding: 3E0000
Address 5F: Information Electr. (J794)       Labels: None
   Part No SW: 5E0 035 842 A    HW: 5E0 035 842 A
   Component: MU-S-D-ER     040 0435
   Serial number: S7E00405141051
   Coding: 03730200FF0000001111120100A800002F0000840100010002
   ASAM Dataset: EV_MUStd4CPASE 002039
   ROD: EV_MUStd4CPASE_SK37.rod
   VCID: 2149030F303C3116BBD-8074
   Media Player Position 1:
   Subsystem 1 - Part No SW: 5E0 919 605 B    HW: 5E0 919 605 B
   Component: ABT_Std_Plus  H50 0022
   Serial number: SKZ8Z9PK60152Q
Address A5: Frt Sens. Drv. Assist (R242)       Labels: 5Q0-980-653.clb
   Part No SW: 5Q0 980 653 F    HW: 5Q0 980 653
   Component: MQB_MFK       H05 0052
   Serial number: 10000072624
   Coding: 0100000001030300000400000100000100
   ASAM Dataset: EV_MFKBoschAU370 001001
   ROD: EV_MFKBoschAU370.rod
   VCID: 3B75D167B2907BC6811-806E
End   ---------------------------------------------------------------------
I have a VAGCOM 12.12 (Not Ross Tech genuine) and there are lot of missing CODING INFORMATION from different ECU’s.
ECU’s without this BYTE-BIT information are:
-          09 CENT. ELECT.
-          13 AUTO DIST. REG.
-          19 CAN GATEWAY
-          42 DOOR ELECT. DRIVER
-          52 DOOR ELECT. PASS.
-          5F INFORMATION ELECT.
Please, anybody have this information files from Ross Tech?
If not, please, anybody have screen shoots of these information’s?
Thank you very much in advance and best regards,
If you had a genuine cable then upgrading from Rosstech is free and you will be on the right version of software for it to work. Your version above is a copied cable so you won't get much help here.
I will leave the post here in case it helps Rosstech (who are members here) in their fight against piracy and then it will be removed in seven days.
Dear Sir,
Excuse me, I understand your reply but, this is not piracy, I think this is the result of a swindle.
At beginning I found too expensive the new RossTech (350€ in Spain) and, I decided to buy a used one for 100€.
It works but is not possible to update it. Then, I think it has a defect or this is not genuine.
Excuse me for the inconvenience,
Best regards,
You need latest version 14.10.1 (at least) for working on Octavia 3.  I have already tested mine on one.
Dear Sir,
Best regards,
Try going to Rosstech site and download 14.1, when connected to the car check ABOUT and it should be GREEN LICENCED if it's genuine.
Dear Sir,
Thank you very much for your replies.
I have downloaded software 14.10.1, the last one, and when tried to make TEST into OPTIONS I receive the error message: Interface not found.
It only works using software version 12.12
Here you have the picture of my device.
VAG%2012.12.jpg?dl=0
Do you see anything that tells you is not genuine?
Regards,
