MFSW and steering wheel control 5K0953569H
I'm fitting a MFSW to my vehicle but I'm having slight problems. The radio buttons on the left are fine but the buttons on the right do this;
The phone button doesn't seem to work other than if you give it a long press it will ring the last number dialled.
The return button below won't do anything.
The scroll wheel will only change the instrument cluster from trip/display 1 to trip/display 2 and vice versa when pressed, turning does nothing.
I ordered the controller 5K0953569H but it seems to have come as a 5K0953569AH. Are these the same?
Address 16: Steering wheel (J527)       Labels: 5K0-953-569.clb
   Part No SW: 5K0 953 521 DT    HW: 5K0 953 569 AH
   Component: LENKS.MODUL   016 0162
   Revision: FF010042    Serial number: 20140722200891
   Coding: 508A144000
   Shop #: WSC 19460 666 12345
   ASAM Dataset: EV_SMLSNGVOLWSXS A01004
   ROD: EV_SMLSNGVOLWS.rod
   VCID: 814ACFBB10285B29E1E-80D4
   Multi Function Steering Wheel Control Module:
   Subsystem 1 - Part No SW: 3T0 959 537     HW: 3T0 959 537   Labels: 3C8-959-537.CLB
   Component: E221__MFL-URO  H07 0012
   Serial number: 2068749
   Coding: 820000
No fault code found.
Address 56: Radio (J503)       Labels: 5M0-035-1xx-56.clb
   Part No SW: 1Z0 035 156 M    HW: 1Z0 035 156 M
   Component: BOLERO        001 0008
   Revision: -----08S    Serial number: SKZ4Z3M1187357
   Coding: 050004010001
   Shop #: WSC 73430 790 00207
   VCID: BC347E4F3F4AF6C1F28-80E9
Address 77: Telephone (J412)       Labels: 7P6-035-730.clb
   Part No SW: 7P6 035 730 N    HW: 7P6 035 730 N
   Component: TELEFON       H15 4217
   Revision: 1B001001    Serial number: 00007699999999
   Coding: 0200000000010110
   Shop #: WSC 12345 123 12345
   ASAM Dataset: EV_UHVNA 002720
   ROD: EV_UHVNA.rod
   VCID: BD32734B2C50FFC9C56-80E8
does the car have a maxidot cluster?
You need a right cluster to fully operate from MFSW.
Know this issue
Right buttons won't work fully without Maxidot. Cluster control is from the right stalk.
The right MFSW buttons should control BT if fitted though.
This is my thread in similar circumstances
http://www.briskoda.net/forums/index.php?/topic/346992-MFSW-retrofit
In summary, without maxidot, only the left side will fully function. The cluster still needs to be controlled by the right stork. I did find once I had retrofitted bluetooth that the phone button on the right hand side would answer and terminate calls though.
I understand with retrofitted maxidot, the mfsw will fully function.
I fitted the maxidot and all worked fine.
One thing of note though is that when you code out the buttons on the wiper switch it needed the car locking and then unlocking before the coding took effect.
  • 6 months later...
   Coding: 508A144000
   Coding: 820000
   ROD: EV_UHVNA.rod
Hello there, i have a question to make
what is the diference of using this module
Address 16: Steering wheel Labels: 1K0-953-549-MY9.lbl
Part No SW: 1K0 953 549 CK HW: 1K0 953 549 CK
Component: J0527 055 0111
Coding: 0000634
Shop #: WSC 00231 447 72242
VCID: 7DDF35AB249FCCD636-8028
Subsystem 1 - Part No: 3T0 959 537 A Labels: 3C8-959-537.CLB
Component: E221__MFL-URO H07 0011
Coding: 00000131
Shop #: WSC 00000
with yours
is it something about G85 sensor
regards
vv
  • 1 year later...
Can i revive this thread a bit? I now have a MFSW retrofit and coded, I have swapped out the Bolero for a Columbus and i have a Kauftec Fiscon Basic Plus for bluetooth (installed by the dealers when i bought the motor). No maxidot and cost and hassle of sourcing one for a petrol VRS in mph is ruling out going that direction. It would be great to get the phone button working (i don't mind if the right side scroll wheel does nothing) but will i need to swap the fiscon for an OEM bluetooth module and if so, part number?
Something else i've noticed; the Columbus seems to drop the phone connection for call audio and keeps on throwing up the connecting user message (every few minutes during a normal car journey). Phone is a Galaxy S8+. Anyone any thoughts on this?
