Washer hose> tank>engine
So im trying to replace the hose, but cant find where it comes out in the engine bay... also is there a good point that already has a elbow/ coupling?
Haven't> got> a> clue> sorry :D
The hose for the rear and front washers are wrapped up with the loom. Near the ECU/ABS pump is the best place to find a join for the rear before it disappears in to the firewall and the front is continuous from the bottle to the scuttle panel I believe and runs up past the ECU through a hole above the strut top.
Ok cheers the bulk head one seems good. But where is it ??? i cant work it out..
Also, off the pump has 2x pipes.. so do they Tee into one? i want to replace the right hand line off the pump .. so can i join off this bulk head and run a pipe to the pump.. is it the right one :P
Pump has 2 pipes, one for the rear washer and one for the front washers... The pipe on that picture looks like the one for the rear where it goes through the firewall.
The bulkhead washer pipe (feeding rear washer as Dan says) is just near the ABS unit (square metal thing with lots of metal brake pipes attached).
