Fuse Box
Does anyone know where the fuse box is on the Roomster? And what size fuses are they, standard or mini blades?
Depending on what fuse you are looking for. The handbook should show the location, but at a guess one end of the dash has a removable panel and some fuses are located there.
It is located at the bottom of the dash, under the steering wheel.
There is a small panel that comes away and holds the fuse removal tool.
I can't remember if they are mini blade fuses or standard size. I'll check tomorrow for you.
Cheers guy's, I'll take a look tomorrow to see if I can find it. Nothing broken yet but wanting to use a piggy back fuse holder to get a switched live, thought about taking feed from rear wiper fuse maybe.
Good call on the rear wiper for the piggy back fuse. It's not 'critical' if there are any issues.
I used this one for my phone charging cradle. :thumbup:
Standard size fuses,
Found it, cheers guys. As said its a panel below steering wheel above the pedals and standard sized blade fuses for most things but have noticed some small fuses too.
