Bluetooth Premium Module 3C8 035 730 A SOLD
Hi all,
For sale is a Premium bluetooth module 3C8 035 730 A for sale.
This module allows either remote sim connection (RSAP) or basic bluetooth connection, allows texts to be read and sent in RSAP mode and also supports music and audio playback via A2DP.
Description:
  • Voice Command
  • A2DP - Bluetooth Audio Stream
  • SMS read/write - in rSAP mode only
  • White MFA+ / DIS ( Driver Informaton System in instrument cluster)
  • Multicolor MFA Premium / DIS
  • Can be operated by:
  • Multifunction Steering Wheel
  • RNS510 / RCD 510 / RNS310 and similar
The module has had its tabs removed to allow installation behind the climatronic panel as opposed to under the seat, however, this does not affect operation nor will it stop it being installed underneath the seat if required.
Pictures:
£65 Delivered
Is this still for sale?
Thanks,
Mark
Sold
Stu did you know you can lock this thread now it is sold?  All you have to do is go to 'Thread Moderation' at the top and select lock.
You can also change the title by going to 'Use Full Editor' in your first post and then you can put Now Sold at the end of the title.
Either of those options will help others who are looking for said item only to open your thread and find it sold.
RegardsChris
Guest
