rear caliper retract
With the rear calipers will they just screw back in, do you screw both sides back clockwise?
When I turned the n/s caliper clockwise it did n't seem to retract.
 you must push the piston in whilst turning it
As above, makes sense.
However you take back the caliper pistons - DO NOT FORGET to place some sort of cover/cloth over the master cylinder reservoir under the bonnet!
Why? Just use brake bleed nipple, much easier...
Quite simply, because many people do not release the bleed nipple - then find that fluid has been chased out of the reservoir!
ah, in such a case :)
