Hello
Hi all. I'm happy that you made a great job. Congratulations.
I'm here to find a solutions for my problem, but first of all, I'll read and search....
Angel
Hello Angel
There's loads of help already on here :thumbup: Just post in a forum if you can't find the answer to the particular problem you have.
Mo
Welcome to Briskoda, Angel. :wavey:
Hi and Welcome.
You should be able to find what help you need.
But if not just give us all a shout.
Have fun
Sarah
Thx for hospitality.
I'll try to find first, at least a post with my problem, but it seems that the problem have only 2 solutions: dealer or PM ;)
Problem (undercover version): 1 key with remote central locking system don't open/close doors, but the red led function. I read the owner manual and execute the "resincronization" procedure described and the remote still don't work. (Skoda Octavia 1.9 TDI Elegance 2003)
welcome :orb_wave:
Try the PM first, you will get a sensible answer
welcome :wavey:
It will need recoding with VAG COM or dealer equipment.
If that doesnt work then it will probably need a new remote.
Hope this helps.
Welcome to briskoda!
Lummox to the rescue again!! :D
Hope this helps.
Lummox Thanks very much, I appreciate your answer. For the moment I change battery to eliminate a eventual discharge (Procedure found here in article sections). I have very good friend that have a VAG COM with usb (DIY) with a ross-tech running software, and first of all I'll try with him, but I'll PM you if is possible to explain the procedure...
Thanks a lot,
a forever learning,
Angel
I must write here, because you solve my problems.
Thanks to you I opened the key, I change the batterys, and recode both flip keys to my car.
Lummox thanks for support and informations.
Thanks very mutch and congratulations.
Angel
Hello everybody!
Any one can help on this problem?
My Fabia 2004 1.4 16V almost since new, has a slow throttle problem from start specially when you stop on any hill and has to start again. I took it to the local dealer several times but do not find anything wrong with it .
Thank for your help
