How to see bluetooth version?
I cannot seem to find out what version is in my Colombus for the BT. I find map version and sw version for the Colombus itself (0370), but not BT. Any suggestions? Thanks
AFAIK the bluetooth version is part of the general firmware number and is not listed as a separate code number.
I will look tonight but I think it is possible in the "phone" menu under bluetooth settings.
One way to know for sure is to upgrade the bluetooth software using the link from the Skoda update site.
It won't tell you what was there before but you will know after the flash.
It seems there is no check of current & upgrade version because I was able to flash the same update 3 times.
Its very quick so I wasn't too sure it it had worked or not.
