oil in coolant water bottle today i saw how to fix it
Today i saw a oil in coolant bottle it a mixture of engine oil in coolant bottle it is a bad smell of ass
how to do tell me please how to fix iwaiting
I would suspect the oil cooler first.
Either oil cooler or head gasket.
Do you mean donkey or anus?
Have you a DSG box? If so are you sure it's engine oil in the coolant? What engine do you have?
I had this a few years ago on my 2007 PD170 vRS.
The oiler cooler had corroded internally.
A new oil cooler, several system flushes and fresh coolant and all was well again.
  • 2 years later...
Finallt fixed. Its oil cooler . Becuz no way here to mixing oil with coolant :)
You left it almost 3 years!? :D
And where in the timeline does this fit with your other post about white and blue smoke? Could your smoke be caused by this oil cooler fault rather than your son squirting water into the air intake?
Brother  my car also giving blue smoke on start  noo way! I cleaned my injectors.... But not the solution...  It is due to low compression bro... I knew there a leak in gasket or incase piston rings or bent...
