abs on a pickup
Hi all just wondering if any one has fitted abs to a pick up as I am under going this for fun planing on using the 256mm up front and golf rear disk on the back I have every think to do this conversion but is it worth it....
Since you have gone the extra mile and bought another Felicia just to get 'every think' for the ABS installation, I guess you already know the answer. Otherwise why would you ask? To see if an ABS does good on a car? Of course it does. But if you just felt the need to tell everybody that you will have the only Fun in the world fitted with ABS and leather seats... I think it is awesome :wonder:
Edited by RicardoM
I had ABS on my Felicia L&K.
After having to make use of it a couple of times I wouldn't be without it on a car!
Phil
I just wrote one off that's why I want abs....
Thanks for that Phil I plan to do the rear disk conversion and 256mm front brakes to run on abs just hope I can pull it all together
  • 3 months later...
Fun now runs abs it's a job well done
  • 8 months later...
Was it a relatively easy job?
Yes it is if you have a doner car to strip the bits off like both front hubs and both rear drums and then there's the wiring loom to take out and then un pick all the wires for the abs side then put in the pick up and had to redo brake pipes all over.
But now it's running rear disk on abs with the 256mm fronts it stops dead....
