Oil problem!!!!
hi, just been out to check the felicias essentials (oil, coolant etc.) and noticed there was a white mayonaise like substance on the underside of the oil filler cap. Does this mean that the head gasket has gone? If so what steps will I need to take to correct the problem?
Thanks in advance
P.S. I know very little about engines and i'm trying to learn
YEP - YOUR HEADGASKET HAS GONE! DO NOT DRIVE THE CAR OR YOU WILL BLOW THE ENGINE UP :shocked:
:P :rofl: Only kidding. The oil filler cap surround acts as a breather and it is perfectly normal to get the mayo accumulating. Give it a wipe out - it shouldn't reoccur to heavily too quickly.
However the head gaskets do blow quite frequently on the 1.3 engine, I know as I've had several. As long as the coolant stays nice and clean (oil free) and there is no coolant loss, there is nothing to worry about. :thumbup:
As tom said keep an eye out for brown slime in the coolant.
You can delay this abit by letting the car warm up correctly, i.e. not ragging it from cold.
