Bluetooth obd readers
To state something even more obvious - do you have the ignition on?
Lol!
Yes ignition on.
Lol!
Yes ignition on.
Then you've done better than me the first time I used VCDS! ;)
Good luck with your problem
Yeah i thought you asked that through experience!!
Which bluetooth reader is best?
Sent from my Galaxy S5
The one I've been using has been great in the past. But i can't get it to read the ECU on this car. Maybe i havnt got it totally pushed in I'll have another look tomorrow.
  • 3 years later...
anyone knows which obd to usb cable suitable for OCTAVIA 1Z SERIES 2009..    MANY CABLES IN EBAY SAYS NOT COMPATIBLE .
VCDS is typically the best option for OBD to USB diagnostics.
An example for an official Australian distributor: https://www.autoequipment.com.au/index.php?route=product/product&product_id=165
If you're likely to use it on more than 3 cars, there are also 10-VIN and unlimited VIN versions or you can upgrade when needed.
VCDS i can download from net, but need OBD cable that compatible with z1 series. this VCDS cable is very expensive.
is there any ebay option?
