Bluetooth module 7P6 035 730 K - £110 inc loom / harness, mic and foam housing
For sale is my Bluetooth module part number 7P6 035 730 K (7P6035730K) for Columbus, Bolero, Amundsen, Amundsen+ or VAG equivalent.
The sale includes everything you need, loom / harness, mic and foam housing ready to affix to your car for HFP Bluetooth telephony and audio streaming.
The kit can be fitted to vehicles with or without maxidot integration although it would be your responsibility to ensure this kit is compatible with your car.
I currently have this fitted and coded to a Columbus so it should work out of the box with another Columbus however may need VCDS coding to fully work with any other media units.
I am only selling as my new car already has a 3C8 035 730 D module and loom fitted.
Collection only from south Birmingham as I would not want to post due to risk of damage. The advantage here is that I can demonstrate it working prior to sale so you could test your phone to ensure paring. This would also enable you to judge the call quality and streaming for yourself to see why these units are so good.
£110
Feel free to ask any questions.
Would this fit/work on a 2009 Octavia with a Bolero stereo unit and no Multi function steering wheel and the basic dash display?
It would. Without mf wheel and maxidot you can only fit a HFP unit like this. You will pair from phone end and select contacts etc. from the Bolero.
Thanks Adam. I had it fitted to an Octy with a Bolero but without maxidot or MFSW and it paired and worked fine but it would need coding for address book download.
I temporarily swapped it over to my new Octy this morning and it worked, paired instantly although I have a Columbus and maxidot pm I got full phonebook download and maxidot display.
If anyone is interested but unsure, I am happy to temporarily fit in your car to pair and test but do not have VCDS to code to enable phone book download. This is ideal and saves the will it, won't it work and the many many hours of research to ensure you get the right kit!
Hi sounds good to me, are you available on Monday evening after around 7? If so pm me your details.
PM'd
If anyone needs this coding in I've got vcds & I'm in bham too
Jon - pm'd you
Murph - would really appreciate that. Will let you know if/when I get it fitted.
Has this sold ? I also have a bolero fitted in mine but to a 2011 model . I take it , it will fit like above ?
Edited by VRS Nick
No, it's still for sale and yes it will fit!
It is on ebay with a starting bid of £120 (fixed price of £110 on here) and finishes tomorrow afternoon and I have someone who wants to have a look on Monday evening but I have not had a deposit so it's first come, first served, ebay included.
Pm me if your interested?
Ill have it. Pm sent
Sold
Guest
