Cigarette lighter not working
Hi - anyone got advice on what to do with my cigarette lighter not working? I use it to charge my phone and until today it's worked brilliantly. I've checked all the phone cabling and charger in another car - all working fine - so it's definitely the car unit.
Could it be the fuse? If so, which one is it?
Could it be the unit itself that's failed? Easily replaced?
Thanks!
sounds like the fuse should be a fuse box one end of your dash if you open your front doors and check the dash you should pull of the panel on the panel it will tell you what number fuse they are the small fuses not sure of rating good luck
On mine it's fuse 30.
Numbered from left to right from top row.
30 is almost in the middle of bottom row.
Says it feeds both lighter sockets.
Thank you both! Appreciate the advice and I'll go and find that fuse.
