VCDS - Coding Foglights as Coming Home Lights
Hello all,
I originally posted this on the Octy III forum but felt this is the better place.
To code foglights as coming/leaving home (CH/LH) light in place of the xenons headlights can I use the following (this has been copied from Andyvee's sticky):
Foglights as coming home/leaving home lights
Controller 09 - Central Electronics
16 - Security Access - enter 31347
10 - Adaptations
(4)-Comfort illumination-Coming Home Leuchten - change to Foglight (Nebellicht)
I was advised that this tweak will use the fog lights and the head lights as CH/LH, after that I will need to disable the feature on both headlight adaptation channels as well. Does anyone know the additonal code to disable the feature on both headlight adaptation channels.
In short I wanted to preserve the life of the xenon bulbs by using just the foglights and DRLs as CH/LH lights.
Thank you in advance.
Updated my sticky with xpowers input on how to do this - we worked out how to do this months ago but I didn't amend the sticky :(
