camber adjustment bolts
as above can you get them and if so where from?
  • Sponsor
Where would they go?
Between the strut and the hub, they have an eccentric cam lobe in the middle, they're a terrible idea but the Corsa boys swear by them.
  • Sponsor
Doesn't the strut fit through a tubular bit in the hub?
don't need em on my corsa got fully adjustable spax suspension was just looking for a cheaper option for fabia
yes it does m8
You can lead a horse to water... :D
Only way to adjust camber on a fab would be aftermarket top mounts, or do as the ford boys do and drill slots into the lower arm to slide the ball joint further out
Doesnt work on a fabia as the shock fits inside the hub
I did use them on my lupo gti however as the shocks bolts to the hub
Depends on car setup if they can be used
"Awesome Sarah" or "TissMe" has done this in the past. - http://www.briskoda.net/forums/topic/171789-ball-joint-position-on-fab-vrs-arms/?p=2083997
Not wholly enthusiastically received in the topic...
I admit, on the mk5 fiesta I first saw the mod done on it looked alot safer, there was more meat around the slots after they were made. It is an option anyway, or get a strengthening plate made up after the slots have been drilled
