NONE OF MY INTERIOR LIGHTS WORK HELP!
can any one help i have checked fuses and the bulb still no joy not one work not even the red door ones or glovebox or evan boot
pulled any fuses? There's a MkI Fabia fuse layout guide in the technical section
Have you tried fuse f4 its 10a
  • Sponsor
There's some info on what supplies all those things (after the fuse) and some diagnostic suggestions in this fairly recent thread.
tryed all fuses
If you've lost the backlighting for the dashboard as well, check your numberplate light , fuse 36 :)
Oh and even if you've checked fuse 4, CHANGE IT  :P   Just in case its something you cannot see.
just been out and tried it no luck  :'(
just asked on this post see if it been solved cheers
  • Sponsor
Have you got a multimeter?
As I said in that thread I linked, you need to find out if the relay is passing any current towards the interior light, when it is supposed to be doing so.
"Main thing to check really is what voltage you see on the red/black (ro/sw) wire coming out of XP2 pin 6, which is almost certainly easier to investigate at pin 2 of the 3-pin connector of the interior light."
Pin 3, the brown wire, is 0V/earth, so check what voltage you have between pins 2 and 3 of the interior light connector as you open and shut the door. If you get nothing at all, trace that red/black wire back to where it starts, at the onboard supply control unit under the dash, and check it there, just in case that wire's bust somewhere along the way.
Another thing worth trying to check is what the voltage on pin 1 of the interior light connector is doing as the door is opened and closed; that should go from 12V down to nearly 0V, I think.
Do the map reading lights work?
i am no good at this stuff haha is this bit on the door where i should be checking could you upload a pic please
  • Sponsor
No, up at the interior light itself. :)
I've edited a couple more suggestions/questions into post #9.
Do the reading lights work if you switch them on?
ok should it be 12v up at that if it is not what do you think it will be?
Comfort module.
Comfort module.
where is this located please
  • Sponsor
Do the reading lights work if you switch them on with their little pushbuttons either side of the interior light?
If they do, that would rule prove that the 12V is getting to the light module.
Under the dash near the foot pedals.
no interior lights in the car work at all
  • Sponsor
Shame, that does tend to mean that the onboard supply control module isn't sending out the necessary 12V.
I haven't got a picture of my own but this current ebay listing shows the module that powers the interior lighting. It sits the other way up with all the wiring hanging out downwards. That part number in that listing may not be exactly what your car needs, so don't just buy that.
is it easy to get too?
I got 1
do they need programing or are they plug and play?
Are any of the puddle lights loose? I got a short when one of mine had broke and it sent the interior lights screwy
will have a check tomorrow mate
all mint had multimeter in them and only 1.7/1.8 volts so am guessing there no power to them someone must have had this problem  :sweat:
