tarox 6 pots
anyone know if 16" spiders will clear tarox 6 pot brakes? any pictures?
What size discs are you running?
330mm discs fit under them fine its just the face of the calliper when tightening wheel bolts catch inside of the spoke on standard vrs wheels they will do up but wheel wont turn with spacers they would fit but don't want spacers tbh
So you have answered your own question, or am I missing something? :)
missing something lol spokes different on spiders to standard vrs wheels
Ah, you meant the Octavia vRS estate wheels. I didn't twig about that. Not seem anyone who has tarox under those wheels. Most big brakes will have put the 17s on. :)
Have you got any pics of your 330mm discs with Tarox kit?
As Tarox don't list a 330mm disc,323mm is the Fabia kit.
they come off a Ibiza I measured the discs when I replaced the pads 3 weeks ago
TT comps with no spacers
One piece discs, or rotor and bell?
one piece these are them behind 17" spiders with no spacers
If you know the et, width of the two wheels and the clearance with 17s you can probably work out clearance of the 16s on the basis the spoke pattern is essentially the same
They are ET 42 if it helps
16.5J x16HZ
I've just noticed these are different to my tarox, what model number do you have steve?
not sure m8 and cars not here atm to check lets see a picture of yours
just found receipt for the brake pads and its sais tarox strada  leon cupra r mk1. that's all I got for now
I'm pretty sure mine are 32-6
(Stolen from GEE'S build thread)
By looking at the caliper clearance there on a 17" wheel i would say there is zero chance of them fitting under 16's
Sure Dav-vrs fit some tarox under 16" wheels with 312 discs so they should fit under there with 330 discs as wel
pm me your number pasty boy
They fit under 16 inch VRS alloys,just the caliper is slightly too deep for wheel to bolt up.
correct but spider spokes are different
