led license plate
Today i used a vcds to code my license plate lights to led. Everything went fine as showed in topics.
however when i instal origninal license plate led lights ( vw passat  2011 or audi a7 2010 ) the fault keeps comming back in my instrument cluster, does anyone have an idea to solve this? It is a octavia model 2015 from november  2014.
thnx
What setting did you change the adaptation channel to - there are quite a few different LED options now.
Try 'LED Lichtmodul'
it is set at the moment to 43 algemein led. but good news, the problem is solved. i tried with other original led's, but no difference, still getting fault codes. placed stock license plate lightening back, fault was gone. left the coding on the led configuration and tried about 3 hours later switching again to led, no more faults. i gues it has to do something with the keyless acces system and ignition. i think that  the ca-bus system needs to go to full rest mode ( 1 a 2 hours ). May come handy if anyone is facing the same problem. But thanks for the fast reply!
thnx
Did you clear the fault code when you swapped bulbs?
Sent from my HTC One_M8 using Tapatalk
yes, everything in fault history was erased 2 or 3 times, but now everything is ok
You can reset the controller with the latest beta of vcds
