Felicia Electric Window Regulator WANTED
Hi,
I need a passenger electric window regulator for my Felicia Magic.The white plastic outer sheath of the cable, which comes from regulator has broken. When you operate the window, the cable spills out of the sheath, and no force goes into putting up the window. Have converted to manual winder for now. The drivers side electric window works perfectly.
That's a common fault with the magic window regs there's one being broke on ebay...
what models of felies had electric windows I'm trying to find at least a passenger one to fit to mine but iv never really found any info!!!
Felicia came in two flavors: LX (w/out special equipments) and GLX (w. special equipments). Depending on sales/marketing policy, GLX cars had power windows as standard or as an extra option.
Over here they were standard on the Bohemia, L&K and SLXi. Didn't know the Magic had them. I know they had the alloys off the SLXi and are all dark grey but don't know if the electric windows are standard. I shall have to keep an eye on this!
My slxi never had electric windows but had air con the magic's have electric windows but they use the same cable operation as manual ones. There is a kit I got from my local skoda garage for £30 that used better regs they are the same as the bohimia ones... I just wish that when I got the leathers from the L&K. I should off had the leccy windows I could off made a mint on them lol
Tried various ways of fixing the sheath but no luck. I still need a winder mechanism, my regulator is still working well.
Dr
Don't suppose you'd have any part numbers so I could try and find some would you?
There the same ones fitted to a bohima
