ecu and coil loom help
Hi I'm chaning over the coil wiring loom in my mk1 vrs and I've done alot of the stripping out but have got a bit stuck.
1) Does anyone have a picture of the wires going into the ecu I can't find a home for wire 94 (black with a thin bit of purple) the other writes were easy to install as like for like on colour.
2) the wires that spur off to the plug by the battery. Is the a technique to getting the pins out?
Would appreciate some advice slightly lost now ta muchly.
Edited by iwik76
numbers on the ECU are there, but they are very very small, I just found the matching coloured wires and soldered them in, lot easier than faffing about with the pins
