PD 130 AZL Engine intercooler connections
Hi all I have some intercooler connections from my old Ibiza that may fit some skodas. I had them on my Ibiza with engine code AZL I believe it was the pd 130 only had them on my car for 2 months till I upgraded all intercooler pipes.
7BF98587-C82A-4C5F-82B9-0A3141D04D98_zps
DD59C408-68E0-4CC9-A918-C531159613F3_zps
There are some dinks in the fittings but that does not affect the seal once you put you rubber seals on them. I'm after £30 + postage for the 2 connectors and the pipe. Any questions feel free to message me.
Where are you mate? What size is the elbow?
What bit was it replacing??
I believe the connectors are 60mm to 51mm and the silicone pipes inside diameter is 51mm. I made the pipe in the picture below number 2 the lower 90 degree pipe. I had to cut the silicone pipe down the one I'm selling is a new ash silicone pipe.
e60c7a34968d765ff9b81bebf1c949ed_zpsm2pl
I'm from Gillingham Kent mate. The pipes a 90 degree Inside diameter 51mm I believe.
  • 4 weeks later...
anyone?
Pm sent
