Engine dead
My dads vrs broke down last night battery light came on and she was makeing funny noises he said so switched it off and called me .... I went got car recoved home looked under bonnet found aux belt had come off and wrapped around crank pulley so i removed crank pulley to remove the exsses old belt and found it had got wedged in the timing belt and liffted it off the crank pulley ;( letting the timing slip .... Iv removed all the crap out and retimed the engine and gone to turn it over by hand shes goes half a turn and then stops so we've definitely had valves kissing pistons id say .... Before i pull head off tomorrow any one ever had timing issues before ??? Whats normally weakest in these im hopeing just bent valves ... But could be cam buckets pistons ect as well ...... Btw he was pulling up to a junction so was nearly stopped not doing 100mph so im hopeing minimul damage ..... Thank in advance
Some valves will be bent but that should be all that needs doing. Good luck.
I got a complete head if interested. pm me
Will defo be intested steve once iv got old one off just to make sure thats all i need thanks
  • Sponsor
Check everything that the aux belt runs round looking for cause of belt failure.
Thats first thing i checked every thing spins free but need new belt on and it running to see properly.... Good news tho thort id have a play this aft to see if i could get it to turn over or take head off and after a hour or so ajusting cam then crank bit by bit i got it to turn freeley so retensioned old belt and she fired up a dream so hopefully shes ok and he turned it off just in time ... Guna stick a new belt on tomorrow and see what it drives like
Fingers crossed, here in Milton Keynes.
SN
Cheers mate ... Put a new belt kit on her last night and she runs like a dream #luckypig :) .... Must have switched her off before any damage was done
