Roomster Air distribution switch not working, always blowing to the windscreen
Hi All
Just got myself a Roomster 1.4 diesel
All good except for the air distribution switch
It blows fine but always blows towards the screen - does not matter if I point it towards the driver of the foot walls, it always blows towards the screen. Did see a PDF, page 46 which shows the layout but could not find out anything on how to fix
http://www.skodafabiaclub.com/technikaiinfok/muszaki_leirasok/SSP_032_4.pdf
Cheers again
Regards
Dan
This is almost certainly either the switch itself, or the flap valve in the heater box.
Do you have output through the 4 "cheesecutters" in the facia? You should, and if not then something else may be at fault.
Check the connections on the back of the switch are all "made" and that the live has power.
Ok, if that's passed, you need to get at the heater box I'm afraid.
Thanks Ken for that
Appreciate your ideas on this, have air through all vents pointing to screen which wont change to anything else (TBH, best position to be stuck at :)
Will check that the switch itself and update if anything
Regards
Dan
