Need a cheap spare wheel - VRS
Hey all,
After being stranded at the side of the road after 2 blowouts, I'm looking for a cheap wheel (alloy or steel) to keep as a spare.
It's a company car so I don't want to pay for a new one really, and the company definitely won't. has anyone out there found another wheel from any other marques/ models that will fit, that I may be able to find on a well known auction site?
Cheers for any thoughts.
James
Look for a 17” 5x112 PCD and a 57.1mm centre bore, most Audi and VW wheels will fit (just be careful as some are 5x100 and some newer Audi’s use a 66.6mm centre bore)
Would still need to get spare wheel and some kind of tool kit as I just found out there is no jack in the car either :(
and check the ET, the Vrs has large Disc's and callipers on the front. Make sure the wheel doesn't catch on the brake set up
Jings, I didn't think of that! What a dope.
Cheers for the replies guys
I'm just about to change from a FL VRs to the Mk3 VRs, will my spare fit the Mk3 ?
No you will need a 17” wheel to clear the front brakes.
Thanks - just checked, mines a 16" :( only used for a day.
I take it that the disks and calipers on the Mk3 are bigger than those fitted to a MY11 FL ?
Would it fit the rear ?
If I had a front puncture then I would need to fit the spare to the rear and move the 18" rear to the front - is this feasible ?
I know it's a double change but if it works i'll be happy :)
Edited by Vrs Led
