support pump water
Regards.
my support pump water out of felicia of the housing, repositioned several times but out of place continuously try placing some screws and metal plates as in the photo, I did not know what to do?
thanks
as in this
Edited by Pollito
Those metal plates are a temporary solution. If you don't have enough money, buy just the rubber bush. But you'll need an extractor and a press to replace it in place. Otherwise buy a new water pump. How old is the water pump?
Thanks for your prompt response.
I think that's age, has about 6 years the water pump but the pump is good in the cooling part, also the support is not broken.
I can go and get the support without the slightest effort.
this piece falls out of the housing
place 2 vertical screw past the base of the boma water and the metal of the bracket. You say friend?
Until you can buy one new pump
Edited by Pollito
