Can I oven clean my powdercoated parts?
As per title really. I need to clean the inside of my TIP and inlet manifold, as there is some powdercoat specs inside from when they were done.
If I were to soak them both completely in oven cleaner, would it damage the coating?
Most powder coats are cured under lowest heats unless yours was a high heat powder coating I wouldn't risk it.
You'll prob find that the oven cleaner will do two things, discolour the outer finished coating and secondly not shift the bits that are inside the manifold etc.
I learnt the expensive way that powdercoating inlet manifolds is a tricky task, unless you are fanatical about the masking/bunging up phase.
Hmmm.... not too sure what to do now to be honest.
There's not much in them, so might just get in there as best as I can and give it a damn good washing out inside.
Sent from my D5503 using Tapatalk
Can you not plug one end up then put the cleaner in, block the other end up and give it a shake every 10 mins or something?
Would that work
Surely specks of powdercoat aren't going to do any harm? Metal or swarf, certainly might.
BTW: Stoopid spell checker doesn't know swarf, tried to use "dwarf".... That would be a little bigger problem. ;)
