Aftermarket central locking
Hello, I have aftermarket central locking fitted, (selca something or other - discontinued from maker and no longer available)
I have one fob, apparently to reprogramme a new fob for this particular central locking system you need a master (red) fob, alas i do not have the red one :(
and to make things worse the button just fell out of my fob :(
I'm not even sure where the control unit is located in the car to be honest... I know there are 4 motors, one for each door as i've seen the bodge job someone did fitting them when sealing my doors (they lost a bit, so they used cable ties and cut holes in the inner door panel - now fixed as best I could and now my doors locks dont jam!)
Ideally i'd like to "upgrade" to a flip key system and install a boot unlocker (I read some people have electronic boot opener)
now.... is it a case of snip n cut n splicey splice and its all gravy?
or do i have to replace the motors n such... or shud I just keep opening my doors with the key like i'm stuck in the 1980s?
Thank you o wisdomful people of briskoda
Edited by SkUG
Buy an rclick kit with flip key, a boot solenoid and away you go ;) just need the blade cutting, swap chip from current key to rclick one and should work.
http://www.rclick.co.uk/product_info.php?cPath=53&products_id=1173
(kit, including genuine vw key shell)
http://www.rclick.co.uk/product_info.php?cPath=55&products_id=278
(boot solenoid)
Wiring diagrams come with these kits, which are quite easy to follow. I fitted one a couple years ago and kt still works fine now, two remotes included and the range was ridiculously good
Thanks, I'll have a look see :)
