Remote windows locking
Octy mk1 SLX 2.0i VIII-2000 Y
I have tendency to forget to close my window from time to time and I was wondering is it possible for this model to set windows to close along with remote door lock and how?
There is already an option to close all 4 windows by holding key in door on lock position + hold.
Thx..
i got this great little item auto up and hold open button goes down and can do it at home  :)
Thx 4 the answers, but this solution is not what I was having in mind.
Edited by mister8ight
What solution are you after?.
I was thinking of VCDS enable/disable feature...if its possible for this model, of course (maybe previous owner disabled this function, like he has already disabled seat belt dash light/sound).
I know what it is your after but its not possible with the standard systems. You can activate it with a program called motordiag komfort manager but you have to hold the button down which is no good if you forget. I think what you want is to press the lock button and then the windows roll up?
Yes, thats it. I saw it on my friends old passat y.1999... :)
thats also what the link i put on does remote total closure and window wind down  / and no seat belt sounds on mine
The only problem with that solution is that it then locks you out of the control module so you are unable to make further changes etc with VCDS.
as basic as these cars are i didn't think there was a great lot in the control module to change, no alarm no lock beep etc? but if i'm missing free unlocks any chance of heads up , i have a spare stock module or two so its right and easy to get to  :p
