Fabia Vrs non cranking
Hi everyone!
Got the wire of death symptoms again (3rd time now) I extended the wire the first time 3 years ago then second time 1 year ago it had broken off at the wire to the plug do re soldered it!
This time it is still connected and won't start if you wiggle the wire while cranking or anything!
Checked power to wire and nothing!
Starter works if I run a wire from battery + to starter terminal, so motor etc is ok!!
Anyone had experience of ignition switch issues?
Is it fuse and or relay fed??
Hope someone can help!
Thanks in advance guys/girls!!
