mot fail!
so usual halfords bull**** number plate light bulb, rear indicators also not yellow.
main ones were drivers front brake line split
and driver side ball joint cover split allowing ingress of dirt
any ideas how easy this last one is?
octavia vrs
I had to replace a ball join on a fabia, was a few bolts, then use a ball join splitter to pop it apart, but you will need to get your tracking done after new one is put in
well halfords wanted 307 for it all jokers!    ball joint is a tenner! think ill get a plsitter tool and have a crack meself
Ball joint cover?
Just throw fresh ball joint on, not bad job
parts all ordered from apd inc bulbs £32 **** halfords!
Shouldn't have even taken it there in the first place
well i know that but. 29 mot its at the top of the road to my works, too easy option.
This is exactly WHY its £29...
Because they earn the £15 back by failing your car in everything :P
i know!!! but actually theyve done my partners w reg golf for 3 years never failed it once, wont be going there again!
but i am tempted to take the wishbone out and fit audi tt rear bushes whilst im there
hers my halfords quote 21.43 for number plate bulb ******S!!!   i will be having words on retest!
Edited by dan281082
A fail is a fail.
If it was mine I would want to know if there are any faults.
I would rectify them myself and be pleased to know that the job was done.
If you can't do it yourself then you have to pay someone to carry out the works.
For a lot of people that sort of price would be fine with them. Halfords are in business as we all are and price accordingly.
You will always find somewhere cheaper and you may find somewhere that carries out the work to a higher standard but unless you try different places, you will never know.
HTH.
A fail is a fail.
HTH.
got no issues with it failing, i do have issues with someone charging 21.43 for a bulb.  that is not pricing accordingly, my company would never think of charging someone 21,43 to change something as small as a bulb which costs a couple pound at best.
As I said, they are a business.
My son is a mechanic and works for Volkswagen at one of their flagship dealerships, you really don't want to know what they charge, that really is criminal!
They Make Halfords seem like a charity.
well i nicked the cv boot replacing the ball joint dnt ask!   so i need to replace that tomorrow , do i just tap the cv joint off to fit the boot/??
Why did you not do a pre mot check yourself to avoid this!
aye i shoulve but im  no mechanic so i wouldntve seen everything.
anyhow sorted the boot and joint not a hard job just getting the nut off the top where is hits the cv joint is ****,
just brake pipe to go,
so this morning after fitting ball joint, and refitting obv the cv joint and boot. which i packed full of grease.    drove the car and it has a awfull squeal much like metal on metal, i have a sneakey feeling its the metal rusty plate that sits behind the hub rubbing something.  its not constant so maybe is rubbing due to tracking?
any ideas.
Jack it up and spin the wheels.
Check carefully everything that you have done!
thats me plan. i can only imagine its something fouling the wheel/hub.   the cv joint wouldnt make that type of noise
was the rusty old disc guard , anyone know the part number for it?
