HELP! VWGOLF tdi problems
Afternoon guys , hoping someone may be able to help, have got a tdi pd115 golf that broke down about a week ago pouring out white smoke and no power, so garage has tested the turbo and said it's not the turbo, and likely to be an injector out, so I've brought some pd130 injectors , the garage has fitted these and now saying the power problem is sorted but it's still pouring out white smoke, now I wouldn't see this as a problem but it's also MOT time so won't pass as it is. They've also plugged it in and no faults have come up !
Anybody got any ideas ????????
Might just some running at high temp to clear the exhaust system? Similar to when a turbo lets go and get replaced - lotta smoke until the systems get cleaned out through use.
ECUs? Why did you get pd130 injectors when the car is a 115? Sounds like a turbo failure to me. But I ain't a mechanic.
Edited by threadbear
