fabia vrs rear caliper bolt.
hi, was changing rear pads on the car, done near side no problems at all.
started doing off side (driver side) was undoing the bolt and it sheared off.
where to go from here? looking on ebay for replacement but not a lot about.
seen caliper pin set would this be any good??
is it still ok to drive as need car for work.
sean.
So one of the bolts shown here at number 1 has snapped?...
If so, a slider pin kit will fix it.
rsz_volkswagen_vw_jetta_passat_cc_golf_m
The bolt on no 1 snapped. Do I need to buy the slider pin kit or can I just buy the bolt? And where? Many thanks
If you can get the broken bit of bolt out a genuine set of pads come with new bolts.
I see. The brake pads I bought didn't come with bolts. Can you tell me the torque setting of the no.1 bolt?
Edited by liberazi
  • Sponsor
Bolt looks like part number WHT003250, available from Skoda dealerships or TPS.
M8 x 22mm long according to this.
You shouldn't drive the car with this bolt missing IMO.
35 Nm  (26 lbf ft)
Thank you for your replies.
