mpg?
Commercial vehicles are limited to the NSL which is 60 mph anyway unless on Motorways.
As to 60mph being more economic than 65 or 70 mph,
that is generally true, but then there are vehicles with engines and gearing that actually use more fuel at 60 mph because that is not the sweet spot for the RPM & gears.
Take as an example 1.4 TSI twincharger as an example that runs through the air quite well at 70 mph and likes 2,200-2,400 rpm and Turbo with no supercharger and in 7th gear.
Then my S60 Volvo Automatic returns a better MPG at 70mph and a bit rather than at 60 mph.
  • Replies 61
  • Views 9.7k
  • I have cruise control on my SEL and done 1 big trip so far and it's already paid for itself. My right foot used to ache heavily after 2/3 hours on my old car. Now all I do is relax and brake if needed
  • hogun pen llyn
    hogun pen llyn
    Just returned home to North Wales from a trip to Scotland. Mostly A Roads and Motorways at what might be considered to be 'Eco' driving. From re-filling the tank, worked out the consumption at aroun
  • with my CC only brake will disengage it, throttle or clutch don't have an impact.
GoneOffSki is spot on. For the past year I've been renting cars only so driven about 32 different cars, each engine had its own sweet spot for best Mpg, I do find 60mph is usually pretty close but a couple have returned better figures at 72mph
I use Fuelly to track my mpg using actual fill ups, not many new Fabias on there to compare with though!  On my last fill up I got 53mpg for my 1.2 90.
  • 6 months later...
I brought my 1.4tdi monte on wednesday and had half a tank on wednesday and its gone already and i do 36 miles a day. Its not much different than my old mk5 golf gti even tho it says im getting 62mpg on the way to & from work but in the golf i was getting 34mpg and half a tank has lasted the same amount of days. Thought the swap to diesel would be better. Obviosly not :(
Welcome.
The Golf did not have the same tank capacity as the Fabia did it?
Do you know how many litres were in when it was showing half a tank. As in did you put them in.
You might find the first half used after brimming lasts longer than the 2nd half, if half on the gauge not being half of 45 litres or so.
Just checked it had a 55l tank. And no i picked it up from the dealership with half a tank already in. So not sure on how many litres was already in there and i couldnt say what fuel was used. I only ever use shell or bp fuel so i will carry out a test with some ultimate/vpower to see what i get
It will be interesting to hear your experiences because there is often debate over 95, or 97/99 Ron Super unleaded, & Premium Diesel over regular diesel
with bigger diesels engines,
but i have never read anyone comparing Regular Diesel from the Major Brands or Supermarket Filling Stations compared to Premium Diesel with a higher cetane
in a 1.4TDI 3 cylinder. ie Is it worth the extra 10-15 pence more a litre.
Well from what my old man has said over the years owning a diesel vag that the vpower & ultimate helps the engine by a massive amount ie runs smoother with smoother feeling gear changes. Provides more mpg. He said you can always tell the difference between each grade of fuel you use. And to be honest he is right, when i picked the car up on wednesday it must of had supermarket fuel due to the lack of mpg i had out of half a tank. I filled the car up saturday morning with 38.6 litres of shell vpower. I am gaining more mpg and the guage hasnt moved and i have done 75 miles. I will keep you updated during the week
well after recently easing off my right pedal I'm getting about 40 mpg .
1.2 tsi colour edition
my 1.2 tsi colour edit does usually smack on 50 mpg on its 20 mile trip in to work on a roads usually 50 - 60 mph. the car has just under 3k on it
1.2 TSI DSG
Average 45mpg, high 50's on long motorway trip if not low 60's cruising at 70 most of the way.
Covered just over 10k miles.
My 1.2 colour edition just tipped over the 10k point, the mpg for the 9.5k I've had it is 50.2. (Measured by actual fuel in).
Edited by Eeeekkk
